54 inch HC Deck
1 reading
2.3K views 5 replies 4 participants last post by  ivel03
#1 ·
Does anyone know if the new HC decks are compatible with older x700 series. I have a 2012 x728 with a 54c deck. I never have been happy with this deck
#2 ·
I cannot answer definitively, but just to give you some hope I am pretty sure they are backwards compatible.
I have a 2010 X748 with 62” deck and would like to know for sure, too. The 62” deck is larger than I’d like, and I wonder about swapping for a 54”.
Someone will let us know soon.
P.S. Welcome to the forum, or congrats on post #2 anyway!
#3 ·
They are compatible but you have to keep two things in mind. They are as tall as a 7-iron deck so will not raise as high as the old deck. And the HC deck requires a different rear draft arm (not arms, it is one piece) about $200 I think.
I do not know if the older tractors can use the auto connect.
#6 ·
They added another hole further up where the lift arms connect to the frame if i remember correctly. Here is a link to the 7 iron brochure - if the HC deck is the same stamping as the 7 iron then it seems to reason that it should fit. 60-in. (152-cm) 7-Iron™ deep-deck mower delivers commercial capability
The main difference will be to swap the separate draft arms for the (double?) T style that is on the later model machines.
Here's the sales brochure for the 60HC:
And the 54HC deck:
I believe that the max lift height is slightly lower on the 7 Iron and HC decks but i'm not positive of that - it might be that the cutting height is the same as the other decks but the shell hangs down a bit further than the other decks (hence the HC) making it seem like it doesn't lift as high.
