This Tecumseh 8hp engine is in a Toro 824XL snow thrower, I think the engine is a HMSK80.
The problem im having is it idles funny, it revs up and down, up and down, up and down. It also does not like a closed choke; I can only close it half way. If I close it all the way it still runs but it makes the revving worse.
So I removed the carb, cleaned it inside and out, replaced all fuel lines and both intake gaskets. The fuel lines and gaskets where all dry rotted. Changed oil also plus fresh clean gas.
Now it starts up on the second pull where before it took 4-6 pulls to get it going. The revving up and down is still the same.
Second thing I noticed is if I prime too much, gas comes out the screw on the bottom of the bowl, it’s always done this. This might have something to do with it.
When re-installing the bowl is there any specific way it needs to be installed? I didn’t take note on how it was installed originally so when I put it back on I wasn’t sure if I had it right. Fired right up so I didn’t worry too much about it.
The only other problem I have with the snow blower is reverse seems to be weak, used to be very strong, if you put it in reverse setting #2 it would knock you down if you weren’t ready for it. Now it just slowly inches backwards. Any ideas?
I was given this snow blower by my father in-law, he don’t take care of anything, he is one of those people that can destroy almost any equipment whether its new or an old iron piece of equipment. If you think you have a piece of equipment that is bullet proof, let him borrow it for a season lol.
